Need Help! Mitsubishi -Tamagawa spindle sensor
Results 1 to 10 of 10
Thread: Mitsubishi -Tamagawa spindle sensor
    Member L98FIERO's Avatar
    May 2003
    Keswick, Ontario
    Default Mitsubishi -Tamagawa spindle sensor
    I'm in the process of rebuilding a Mitsubishi M-V5B VMC with an integrated spindle motor that has what I think is a magnetic sensor for rotary position, it is a Tamagawa AU5589-6590-1382 and I've not been able to find out anything about it, don't know the voltage supply requirements or what signals it will output. Someone else started the retrofit and left it in the middle and I was told it required +15 DC power and output only 5 of the 6 output signals required for my new control (A, A', B, B', Z and Z'). I believe he said it was missing one of the Z signals. There is not a lot of information about this component on the internet!
    Registered sansgp's Avatar
    Oct 2008
    singapore
    Default Re: Mitsubishi -Tamagawa spindle sensor
    L98FIERO
    Ref. Tamagawa AU5589-6590-1382.. it is the spindle magsensor amplifier PCB & feeds amplified signals into the spindle drive.
    It requires +/15V power to operate. The outputs PA & PB are essentially sine waves and the frequency depends on the spindle RPM. For every 100RPM, my scope measured about 850Hz.The output voltage is seen between (+/- 1.5 to 2Vpeak) or 3Vp-p to 4Vp-p. Hope these helps.
    May 2003
    Keswick, Ontario
    Quote Originally Posted by sansgp View Post
    L98FIERO
    Thanks for the reply but as you can see, my post was from 2015 and we never did get the machine running, it was eventually scrapped as Mitsubishi refused to give any assistance in getting the 'built-in' spindle motor powered up. They flat out refused to give any useful information from either the Canadian or US offices. I really liked the control when it was working but as of that experience there will be no more Mitsubishi controls in my shop.
    mazak-user's Avatar
    Oct 2003
    Maribor
    Quote Originally Posted by L98FIERO View Post
    Hi, give me your mail, I will send you some data sheet.
    Gesendet von meinem SM-N910C mit Tapatalk
    May 2003
    Keswick, Ontario
    Gesendet von meinem SM-N910C mit Tapatalk[/QUOTE]
    Thanks for the offer but the machine has been scrapped.
    Sep 2006
    indonesia
    [QUOTE=mazak-user;2067636]Hi, give me your mail, I will send you some data sheet.
    hello,
    I wondering the same thing, please send also to my email address.
    nasteknika@yahoo.co.id
    I want to retrofiting Spindle Driver with Delta VFD-V close loop.
    Thank you
    Nastek
  7. #7
    Aug 2015
    Please send me Tamagawa AU5589 manual
  8. #8
    Member Justin15's Avatar
    Mar 2024
    Hi, would you be able to send me that data sheet please?
  9. #9
    May 2003
    Keswick, Ontario
    Deleted
  10. #10
    Member EquimachGSK's Avatar
    May 2024
    Quote Originally Posted by mazak-user View Post
    Hello Mazak-user! If you could, please send me the datasheet for this encoder. I have a DMG that I am currently retrofitting, and i need to understand how this encoder works. I saw in the top coment post it is 15VDC powered, but i also need to know the signals it outputs, so that i can try and get a servo-drive from my system to read this signals and controll this eletrospindle. Regards, Bernardo Martins from Equimach Portugal
    my email: geral@equimach.com
