EDM Discussion General Topics
Page 1 of 38 123411 ... LastLast
Threads 1 to 20 of 754
Forum: EDM Discussion General Topics
Discuss building, operating EDM machines here!
  1. Need Help!- Die-sinking EDM can’t set axis
    Started by Kamol1809‎, 03-18-2025 02:58 AM
    axis, machine, p.s, press, setting
    03-18-2025, 11:33 PM Go to last post
  2. Exclamation Need Help!- Help needed. Sodick A500W, problem filling tank.
    Started by IACDaniel‎, 05-28-2015 07:09 AM
    03-18-2025, 10:18 AM Go to last post
  3. Need System Backup for Charmilles Robofil 310
    Started by ashakus‎, 03-13-2025 03:34 PM
    03-13-2025, 03:34 PM Go to last post
  4. Need Help!- Fanuc EDM Alpha-OC Reference Return
    Started by frinkdaddy1‎, 03-06-2014 01:51 PM
    03-13-2025, 02:11 AM Go to last post
  5. Need Help!- Charmilles SH2 EDM Drill Operation & Programming Manuals
    Started by Moldmaker2‎, 03-12-2024 07:42 PM
    charmilles, charmilles sh2, edm manuals, sodick kcn, software
    03-11-2025, 12:33 PM Go to last post
  6. Need Help!- Fanuc A0-1 cutting stops or fluctuates
    Started by tlmkr38‎, 08-30-2023 07:36 AM
    burn, cutting, time, water, wire
    02-24-2025, 08:47 AM Go to last post
  7. anyone still using an Agie DEM series wire machine?
    Started by klrskies‎, 04-12-2024 07:55 PM
    dem, fasttrak, mine, running, worked
    02-20-2025, 04:45 PM Go to last post
  8. Looking for Brother HS-300 EDM PC software
    Started by ppaing126‎, 02-02-2025 04:07 AM
    brother, edm, hs300, machine, software
    02-11-2025, 12:10 PM Go to last post
  9. Need Help!- Brother hs-70a language change
    Started by Delav‎, 02-09-2025 03:54 PM
    brother, change, hs-70a, language, system
    02-09-2025, 11:31 PM Go to last post
  10. Red face Need Help!- PCM TO DXF
    Started by emichaud‎, 02-06-2025 10:43 AM
    attach, dxf, file, machine, pcm
    02-06-2025, 10:43 AM Go to last post
  11. Post (ROBOFIL 290P) E697 POWER SOURCE ERROR E2
    Started by leanmen‎, 02-05-2025 01:52 PM
    02-05-2025, 01:52 PM Go to last post
  12. Sodick AP350
    Started by cmetal‎, 01-31-2025 03:02 PM
    01-31-2025, 03:02 PM Go to last post
  13. Charmilles Form 20 - Err GAP
    Started by Fantasta‎, 02-02-2015 05:09 AM
    charmilles, err, gap, look, start
    01-14-2025, 09:49 PM Go to last post
  14. Pulse Sinker EDM / CNC Cook Book / Ben Fleming
    Started by DaleW‎, 12-26-2024 09:16 PM
    12-26-2024, 09:16 PM Go to last post
  15. Need Help!- FANUC ALPHA 1-ib EDM machine from 2002 - can't find parameters
    Started by msavcic‎, 12-16-2024 05:48 PM
    alarm, fanuc, find, machine, type
    12-26-2024, 05:27 AM Go to last post
  16. Need Help!- FANUC ALPHA auto wire threading water jet not working
    Started by msavcic‎, 12-26-2024 05:03 AM
    auto, guide, threading, water, wire
    12-26-2024, 05:03 AM Go to last post
  17. Charmilles Robofil 510 - E903 Regulator UPA error
    Started by xert‎, 09-30-2024 01:05 PM
    charmilles, error, generator, regulator upa, robofil
    11-28-2024, 12:03 PM Go to last post
  18. Brother HS-70A wire EDM, edge detection and centering
    Started by jarppa‎, 04-18-2009 06:05 AM
    already, another, not, then
    11-11-2024, 07:14 AM Go to last post
  19. Strange problem with charmilles foboform 35
    Started by mehom‎, 11-05-2024 08:56 AM
    11-05-2024, 08:56 AM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 6 users browsing this forum. (0 members & 6 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
