XYZ Gantry Routers
Page 1 of 3 123 LastLast
Threads 1 to 20 of 60
Forum: XYZ Gantry Routers
Discuss XYZ Gantry Routers here!
    09-11-2024, 03:37 AM Go to last post
  1. AXYZ ball screw hardware
    Started by johnk1978‎, 09-09-2024 09:20 AM
    09-10-2024, 08:52 AM Go to last post
  2. Need Help!- Can't set up a used machine (AXYZ)
    Started by Angelok‎, 04-17-2024 02:01 PM
    axyz, cnc, machine, software, tool path
    07-22-2024, 02:53 AM Go to last post
  3. AXYZ 4008 3 phase to single phase wiring
    Started by roguedog‎, 06-07-2024 02:14 PM
    06-17-2024, 02:27 AM Go to last post
  4. AXYZ 8016 Toolhead Home positions
    Started by mpuissant‎, 04-25-2024 09:40 AM
    04-26-2024, 04:39 AM Go to last post
  5. Spare parts For AXYZ
    Started by davidrid‎, 11-23-2020 07:06 PM
    04-22-2024, 03:37 AM Go to last post
  6. Need Help!- AXYZ Router 8153 model PANELBUILDER SENSOR ISSUE!
    Started by axyzrouterguy‎, 03-27-2024 04:42 PM
    03-27-2024, 04:42 PM Go to last post
  7. Question Need Help!- AXYZ 4008 Router Trouble With Toolpath and Vectric Aspire
    Started by DomKas‎, 06-14-2023 07:14 PM
    axyz, axyz 4008, axyz cnc router, cnc 3 axis, vectric
    02-15-2024, 09:33 AM Go to last post
  8. Question Problem- CNC steps offline after initial ramp move
    Started by The_Bengineer‎, 11-17-2023 10:17 AM
    11-17-2023, 02:04 PM Go to last post
    11-09-2023, 10:57 AM Go to last post
  9. Moved: Need Help!- 4PS Presision & Speed
    Started by Tman1973‎, 11-03-2023 11:09 PM
  10. Exclamation Need Help!- Aluminum Chip Welding
    Started by axyzrouterguy‎, 10-23-2023 05:14 PM
    1/8, aluminum, bit, cut, sheet
    10-23-2023, 06:04 PM Go to last post
    10-15-2023, 05:23 AM Go to last post
  11. Moved: Anyone know these machine's brand?
    Started by Vilyoo‎, 09-18-2023 11:54 AM
  12. Axyz router spindle wiring
    Started by Timdenton‎, 08-11-2023 02:43 PM
    08-12-2023, 06:27 PM Go to last post
  13. AXYZ 5010 Table Breaking Bits After Upgrade
    Started by dosu170‎, 08-09-2023 09:46 AM
    08-09-2023, 09:46 AM Go to last post
  14. AXYZ randomly freezing/ restarting
    Started by Five06‎, 06-15-2023 11:31 AM
    06-16-2023, 02:15 AM Go to last post
  15. Unhappy AXYS 4010 Boot failure
    Started by TonyG1701‎, 04-26-2023 06:01 AM
    a2mc, axyz 4010, boot disk failure
    04-26-2023, 06:01 AM Go to last post
  16. Need help Axyz 6010, error 14, transmission error
    Started by Monq‎, 04-06-2023 05:14 AM
    axyz, axyz 6010, error 13, error 14
    04-06-2023, 05:14 AM Go to last post
  17. Need Help!- AXYZ 4008 error code 803 - not in the list!
    Started by Messir‎, 03-15-2023 04:44 AM
    axyz, cnc, error, offered
    03-17-2023, 04:01 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 1 users browsing this forum. (0 members & 1 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
