- VMC 800-30 parameter file needed for TNC410PA control
Hi all,
I'm trying to locate a parameter file for this machine, as the original was lost due to a breakdown & power loss.
(The PLC is in EPROM, so that's still intact.)
I've tried files from a VMC 800-22 with an earlier TNC410, but the motor parameters are different among other things, and it errors out when trying to power up.
I've also got a backup from an 800-30 with a TNC426, but that again is too different a system to be any use.
Any help greatly appreciated!
Robert
- You may not post replies
- You may not edit your posts
Forum Rules
