Need Help Takisawa TC-20 Fanuc 21-T Over travel error
I can't home the X or Z.
Attempt to home the Z come up with a error "500 over travel in the +Z". It fails to move to or away from home.
The X will move away from home but not to home.
Any idea greatly apricated.
Tony
re: Need Help Takisawa TC-20 Fanuc 21-T Over travel error
If your current location is already overtravel, I recommend that you disconnect the machine and move manually (rotating yourself the screw) to a location that will overcome the limit.
Check if the limit switches are working, then proceed as normal.
I have wound the screw back manually but it doesn't make any difference.
.I wonder if the position encoder is showing the incorrect number on start up and assumes its to far.
if the zero return way is on + plus side ,you can increase the limit on paramater 1320 with 999999 ,move the axis in minus direction around 100mm,make the zero return and fater that put back the value you found on 1320
I tried that and it still didn't let me move in the -Z, I also can't move the X in the home direction. I have checked the drives and it doesn't show any error. Seems the Z & X will only go in one direction.
Thanks for your suggest all help is greatly apricated.
Tony
did you have a tool setter on the machine or the machine had one?The tool setter can block the machine go only in measuring direction
Also can you send a picture with the first diagnose page while you try to jog the axis?
When I use 1320 at 99999999 it allows me to travel to the home but I can't move back. When I put 1320 back to 5000 (what it was) and wind the ball screw back by hand with the power off. Power up thentry to move to home it errors. I attached pic's.
Tony
If I change 1320 Z to 99999999 as you suggested before I can move right to home on the Z axis but if I leave it at the current setting it just errors with out moving at all. Attached are the images you requested.
Tony
Position after error.
Is axis 3 the C axis?
What is axis 3?
in the parameters it seems that the 3 axis is using absolute encoders and not incremental
you need to go to the reference point if you know it and make the APZ from 1 to 0 ,restart machine,put back the APZ to 1 ,restart again
in this way the new reference point is taking where you let the axis
Re: Need Help Takisawa TC-20 Fanuc 21-T Over travel error
Axis 3 is the turret tool position.
By reference point do you mean the home position.
Do you know the parameter to turn off the tool setter as it maybe causing the issue and if we can tell the controller it doesn't have one we may get the X & Z to move home.
Because you have APC and APZ set to 0 it means you have incremental encoders using dog for deccelerating and finding the reference marker.
You can increase the limits ,make the reference zero and put back the values you found there and will solve the problem
Problem fixed, it was broken wires in the tool setter went into X1004 and you could see two of the 4 points was not working. They normally function by NC. Once I repaired the wires I had to adjust the limits using 1320 to get the X home and now all great.
Thanks heaps for you input Zavateandu your taught e heaps.
Tony
Hello sir did You fixed thias problem?
I got the same issue, fixed it by replacing the X axis limit switch, the actuator was worn, Your problem should be something similar or a dirthy limit switch on X or Z axis.
Now I have a VRDY OFF Alarm on both axis Have You had this problem in the past?
my machine is also a Takisawa TC-20 Lathe with Fanuc 21TB Control.
I do not have neither the Ladder Diagram Nor the electrical schematics for my machine.
Jose
