It's just repositioning, Z up position means where material starts and engraver wants to mill everything from this height.
Hello!
I have an old Roland MDX15 engraving machine. I use DR. Engrave software.
When I set up parameters:
Z Up Position 5mm
Z Down Position -40mm
Z Engraving Pitch 40mm
I don't understand why my Z Up Position values don't work. When machine makes idle moves it raises the z-axis slider to the maximum height. What am i doing wrong?
Video: https://gemoo.com/tools/upload-video...64178002051072
Thank you for your help!
It seems to be working okay. What do you mean by "set up parameters"? Is this an attempt to edit the post-processor, or give it motion commands? Where did you set your zeros? Usually they are set in relation to a workpiece, but you don't seem to have one there.
I think Z0 means where material starts and Z up positsion is repositioning height?
picture : https://ibb.co/yRN1ktF
Yes, I don't have a workpiece. I just test the program and machine. On this machine, Z0 can only be set manually (engraving bit moving in tool holder). ther is only 3 values programming to Z axis (Up position, Down position and pich), When I change Up position value nothing changes.
I just said what i observed on my modela. It always repositions on Z maximum. Z Up is where the cutting movements start. All above are rapid (let's say that this toy has rapid ones )
Z=0 is a base height for cutting or engraving. Sometimes U may plan surface before engraving and sometimes u have a flat, but not perfect. In this case u need to fit flatnes between Z0 and Z Up. It is like a safety distance.
Thank you for your answer.
I think my Z up cell is not working You said that Z up is where cutting starts but whatever number I write into that cell machine starts calculating cutting on Z axis maximum height.
For example, if I want to engrave a thin plate and engraving step is 0.05mm and the z down position is -55mm. Then I would have to wait about 1 hour before the engraving blade touches my part. Because it starts engraving from the maximum height of the z axis - even if I put the Z up position value 54mm.
I made a video, there is 2 experiments : z down and pitch dimensions are same -40mm and 20mm. I changed only Z up position parameters first time 30mm and second time only 1mm and unfortunately no difference, cutting start height is same
https://gemoo.com/tools/upload-video...12029242003456
You need to zero the tip of your tool to the top of the material you're engraving. It sounds like you're setting it at the top of the Z axis instead. It automatically goes there when it retracts; you don't need to put a value in for that.
U know that U can mount spindle in two positions?
If U mount it in lower position even short tool will reach table.
Also U set machining height by moving spindle with up and down buttons beneath on/off.
There should be still available manual on rolanddga site
