Hi - Cope is top and drag is bottom. The drag mould is "dragged" around the floor is one way to look at it... Casting is done for a few reasons 1) if your going to make many parts casting is economical 2) if its a material like CI and you want it for its tribological properties or its damping qualities then casting makes sense 3) maybe its a shape you can't machine... Commercial machine builders cast because they make lots of parts and in the past where ways where machined into parts they use CI as its slippery. These days using rails, that side of the material does not matter. Using ready available steel , welding yourself and machining is traditionally the cheapest solution... Moulds and pouring take energy and that costs a lot for a bespoke part... But explore options. Nows the time to do that... There are machines here that are made from aluminium that have been poured at home... Peter
