need help - zeroing material xy
Results 1 to 4 of 4
Thread: need help - zeroing material xy
    Member Goo67's Avatar
    Feb 2019
    Angry need help - zeroing material xy
    when i zero my x&y to material i have to use outside edge of tool instead of center of tool. is their a setting some where to change. What happens when i zero on center of tool it cuts half the diameter to the right. pats come out correct size just wrong place on material. I Use mach3&vectric aspire.
    Member awerby's Avatar
    Apr 2004
    Default Re: need help - zeroing material xy
    When zeroing with a tool to the edge of your stock, you need to compensate for the radius of the tool. So, for instance, if you were using a half-inch tool touched off to the edge, you'd add a quarter inch if it was on the negative side, or subtract it if it was on the positive side. If your controller doesn't let you put in any value but zero, move the tool up to clear the stock and a quarter-inch over to the edge, then press the zero button. Usually it's recommended to do this with an edge-finder instead of the actual tool, to avoid damage to the tool and/or the stock.
    Feb 2019
    thanks, for your answer.
    Feb 2019
    Thank You AWERBY for your answer it got me going in the right direction. i purchased 2010 screen set and it simplified everything. thanks again
