Hmmmmmm....... Not yet. Broken Tools, Inserts, Snapped 1-1/4 Diameter End Mills, Melted Index Drills, Shattered HSS Drills, Snapped Groove tools, Cracked Windows, a few Dents in the Doors and cut too much on finish passes. Never made any contact with Machine Tool Components.
Watched one guy send a 6" diameter 1" thick 8620 Disk throught the top of the machine and the roof. Meat-Head exceeded the Jaw Stroke Limit, didn't have the right PSI on the chuck, and too high of an RPM. Zing!!!!!!!!!
Another extended 5/8 Hex stock 2 feet out the back of the spindle destroying the way oil tank and a few other things.
Once a Cut-off part got caught between the Turret and the Chuck during cut-off. That was a loud one.
This one too.
http://www.cnczone.com/forums/showpo...&postcount=109
You guys are scary beyond scary.
