you can not control the line thickness using print command. Print is just a snap shot of Graphic screen display.
However if you specify clearly about your problem in installing a printer to use Plot command i can help you. I am using plot command on NX4 and its working fine with me.
The basic procedure is using plot admin first create a plotter model and then assign a system profile to it.
