- Need Help!- UC400ETH - Gecko G540 and HY 110 1.5KW VFD Parameters Help
Re: UC400ETH - Gecko G540 and HY 110 1.5KW VFD Parameters Help
You need to configure UCCNC to control the spindle using PWM and use two outputs to control the FOR and REV signals. The info you are looking for is in the manual of the G540.
Arturo Duncan
https://cnc4pc.com
got it pretty much figured out thru trial and error - it was a combination of the low active setting. only thing i really want is better RPM control - numbers are way off from VFD to what s command tells it - my suspicions are it must be voltage setting in VFD and thank you for your reply Arturo
- You may not post replies
- You may not edit your posts
Forum Rules
