- Need Help!- Inverter huanyang 1,5 kw 220v. error ELus
Re: Inverter huanyang 1,5 kw 220v. error ELus
Manual says Low voltage coming in
thanks friend, I opened the inverter I saw many electrical problems, ELus "low voltage" problem has been solved, now other communication problems with PC, I replaced the inverter with a new one and now everything works. thanks for the support
- You may not post replies
- You may not edit your posts
Forum Rules
