- rhino 8 points
rhino 8 points
When drawing a circle or rectangle, is there a command to turn off points when the circle is highlighted the points automatically appear, is there a command to disable that?
Rhino 4 doesnt do that, I have to turn points on if I want them, rhino 8 they appear automatically when the curve is selected.
Re: rhino 8 points
I figured it out, there is a check box for it.
Re: rhino 8 points
Just check it at Rhino 7. Guess 8 must be same
Go to Tools-Options-View-Display Modes
Choose desired display mode. Go to Objects
There is "Hide control points" in Visibility section
Enjoy!
PS: Take a note - control points are invisible, but active. If you press F10, you still cannot see it, but can choose
- rhino 8 points
- You may not post replies
- You may not edit your posts
Forum Rules
