RFQ: A36 HOT ROLLED STEEL Plates (Small Quantity Job)
Results 1 to 8 of 8
Thread: RFQ: A36 HOT ROLLED STEEL Plates (Small Quantity Job)
    Feb 2013
    Default RFQ: A36 HOT ROLLED STEEL Plates (Small Quantity Job)
    Quantity: 100 Upper Blade, 100 Lower Blade. Total: 200 pieces.
    See attached.
    Thank you.
    Dec 2013
    Default Re: RFQ: A36 HOT ROLLED STEEL Plates (Small Quantity Job)
    There doesn't seem to be an attachment
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2013
    Quote Originally Posted by ahk199 View Post
    See attached.
    Thank you.
    ATTACHMENTS HERE
    RFQ: A36 HOT ROLLED STEEL Plates (Small Quantity Job)-lower_blade_for_rfq-jpg
    RFQ: A36 HOT ROLLED STEEL Plates (Small Quantity Job)-upper_blade_for_rfq-jpg
    Member SELEADCNC's Avatar
    Oct 2021
    Hi, what's the thickness of those parts?
    Mar 2008
    You are missing a critical dimension, length. also your print says 0.025 thick material, but the drawing shows it would have to be 0.5
    Feb 2013
    Apologies for the typo. Material is .125" thick. See attached. Will provide higher quality pdf's with job. Thank You.
    RFQ: A36 HOT ROLLED STEEL Plates (Small Quantity Job)-img_1552_sm-jpg
    RFQ: A36 HOT ROLLED STEEL Plates (Small Quantity Job)-img_1551_sm-jpg
  7. #7
    Mar 2006
    Did you get these done?
    I can do them ASAP if needed.
    Message me for pricing.
  8. #8
    Member anokmould's Avatar
    Nov 2014
    ShenZhen
    See attached.
    Thank you.
    could you send me you email ? I can send our quota sheet here
