Did you try to set F26, F27?
You should set F26=7, F27=1.
"Motor Sound (Tone) (F27): Changes the motor running sound tone. This setting is effective when the carrier frequency set to function code F26 is 7 kHz or lower. Changing the tone level may reduce the high and harsh running noise from the motor."
