You only listed one.
If you're talking about the 8020 machines, most of them use components from CNCRouterParts.com
First, even with the Nema 23 motors, the spindle will be the limiting factor in how fast you can cut unless you spend a few thousand $$ for a 5HP spindle.
And I think at that point, you'll find that the aluminum extrusion and skate bearing carriages are not really up to the 5HP spindle.
I haven't seen anyone mention that precision is an issue with any of these machines. Stepper powered machines will always have to trade speed for precision, due to the fact that a steppers torque falls off with rpm, and the only way to get more precision is to spin the motor more times, which equals faster.
Imo, if you need more speed than you can get with the Nema 34 rack and pinion drives from cncrouterparts, you'll need to go with servo drives, and ideally custom made drive components with a much higher reduction ratio than the 3:1 that everyone is using with steppers.
