I jjust opened the Fusion supplied Milltronics post and found this:
Code:
function defineMachine() {
var useTCP = true;
if (false) { // note: setup your machine here
var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120, 120], preference:1, tcp:useTCP});
var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[-360, 360], preference:0, tcp:useTCP});
machineConfiguration = new MachineConfiguration(aAxis, cAxis);
setMachineConfiguration(machineConfiguration);
if (receivedMachineConfiguration) {
warning(localize("The provided CAM machine configuration is overwritten by the postprocessor."));
receivedMachineConfiguration = false; // CAM provided machine configuration is overwritten
if (!receivedMachineConfiguration) {
// multiaxis settings
if (machineConfiguration.isHeadConfiguration()) {
machineConfiguration.setVirtualTooltip(false); // translate the pivot point to the virtual tool tip for nonTCP rotary heads
So I rather suspect the post has both four AND five axis capability and TCP capability as well, although I'm less sure about this last feature. Either way you need to enquire of Autodesk how to activate
the fourth axis.
Craig
