Straw is valuable material for pellet production due to original low cost waste made by agricultural planting. The same as other wastes produced in different business, the characteristics of straw includes abundant storage, high caloric for burning, and stable supply in all seasons. At present lots of clients start to use straw for pellet production and the finished pellets are available for both of residential and industrial use.
Straw pellet machine is also named as straw pellets making machine or straw pellet mill, which is mainly developed for the materials of straw plants such as corn stalks, wheat straw, cotton straw, etc. When it comes to buy a proper straw pellet machine, majorities of people find it difficult to choose because of the wide variety of pellet mills on the market today. There are several aspects should be considered before purchasing a suitable straw pellet mill.
1. Types
There are several types of straw pellet mills, and it is important for you to select the type that matches your needs best. Some pellet machines are used for wheat straws, some are for rice straws and some are for sawdust. It is important for you to take all your needs and tastes into consideration, which will help you in purchasing the right machine.
2. Specifications
Pellet mills for straws have different specifications. Therefore, it is important to check out each specification comes with the pellet mills in terms of efficiency, consumption, energy and the materials, which will in turn help you make the right choice when it comes to purchase.
3. Comprehensive Cost Performance
Comprehensive cost performance of pellet machine can be reflected in many aspects, such as power configuration, abrasion of wearing parts, self-stability, continuous working efficiency, output per unit time, use and maintenance, etc.
