Hi Eye - Don't use a 2.2kW spindle for this project. Its too heavy for the structure you are talking about (plus you are driving it with belts that will be springy and its mass will take a long time to stop vibrating) Use an 800W or 1500W water cooled spindle. If 1500W use a Er16 collet. That will take 10mm bits which for guitar work is a very good size... My first machine used 16mm AT belts and these proved to be very good. Made many necks and guitar bits for people using a 500W DC spindle. But I strongly recommend you do not use a belt for the Z axis. Too springy, which I found out on my first machine. When plunging you need a very stiff Z axis. Use a 4mm or 5mm pitch ballscrew for the Z axis.
Leadscrews are an unfortunate choice due to backlash and keeping them synchronised will be difficult, especially on the lifting Z axis. I recommend ballscrews.
15mm belts are strong enough but are springy, I'd go 25mm minimum after using 16mm belts on two machines. But go ballscrews, by the time you sort idlers, custom brackets and tensioners you are at same cost as ballscrews without the hassles and much much better performance.
Think through the lifting gantry a bit more. If your Z is 500mm ? It may not function as you thought it may. A long stiff Z is probably better then a lifting gantry. Plus make the machine a high rail design its much stiffer and keeps the dust out of the mechanics. See images attached.
Attached are photos of a mainly plywood machine I have just sold it goes to a surfboard shaper to make fibreglass fins. It cuts timber, plastic and aluminium very easily and it uses an 800W water cooled spindle. A bigger spindle does not mean you can cut any faster or deeper if the structure is not up to it. A 2.2kW spindle is a big heavy beast that requires a really big solid gantry to get the best out of it.
An 80x80mm gantry is not up to it, try for at least 100x100mm in steel and 120x120mm or a bit bigger in ply. A solid plywood gantry is stiffer and damper then a thin steel one and usually lighter. I'm making a 3m long plywood gantry at the moment for a 8x4 long ways machine. I'd flick Mach3 and look at Knighthawk (KN)/Commander. You can use the KH board with the drivers you have bought. The KH can use your mobile phone as a pendant which is really good. Its also wireless and by the time you buy a motion controller and machine controller your $$$ are more than the KH.
You won't need counterweights if designed well. Time to get busy on CAD and get a design together. Peter
Oh DM556 drivers - use the max voltage they can take ie 48V. The higher the voltage the smother and faster the motion.
- - - Updated - - -
- - - Updated - - -
