Need Help! Mazak VTC-30C with Mazatrol M-Plus
Results 1 to 9 of 9
Thread: Mazak VTC-30C with Mazatrol M-Plus
    Member Foreigner1976's Avatar
    Sep 2023
    Default Mazak VTC-30C with Mazatrol M-Plus
    Hi!
    I have such problem. In the morning, I turned on the machine, run all axes to the machine zeros and received the error 2 EMERGENCY STOP. I turned off the machine with the rear switch and turned it on again, but the green button on the control panel did not light up. Found that the 24V 120W power supply unit is not working. Disassembled and repaired the 24V power supply, the green power button on the control panel is now light, but the following alarms remain active:
    2 EMERGENCY STOP
    3 EMERGENCY STOP
    382 SPINDLE POWER CUT MALF.
    383 PLC EMERGENCY STOP RELAY FAULT
    385 ESTOP SAFETY RELAY FAULT
    Please help.
    Sep 2023
    Default Re: Mazak VTC-30C with Mazatrol M-Plus
    Anybody knows anything about this problem? All LEDs are lit or blink green on all units. No red LED
    Sep 2023
    Problem is solved.
    Member machinehop5's Avatar
    Aug 2009
    ...what was the problem ?
    Member ANDRZEJAKSA's Avatar
    Jun 2023
    Quote Originally Posted by machinehop5 View Post
    Jak rozwi?za? tenproblem?
    Jun 2023
    Jak by? problem....
  7. #7
    Jun 2023
    Quote Originally Posted by Foreigner1976 View Post
    Problem is solved.
    Help!!!!
  8. #8
    Jun 2023
    Hi!
    2 EMERGENCY STOP
    3 EMERGENCY STOP
    Please help.
    Help...
  9. #9
    Sep 2023
    I apologize for the late reply. The reply notification does not work.
    In my case it was a software problem. I performed the memory reset procedure, reinitializing memory and all the errors disappeared, the machine works normally.
    If you do not know how to do this, then I will try to explain this procedure.
