- TITAN DNC on PROTOTRAK
Junior Member
Hi Ive got a Titan DNC units to use on my old PROTO TRAK MX3 CNC Mill
Im having problems with it not completing a large 3D file
Its generating a coms error about 3/4 away throw the file
I think its something to do with the handshake the proto trak
requires a XON XOFF on its setup it dosnt have this setting
Can you help or do you have an idea of a product that may work
Did you get the 5 pin cable? hardware xon/xoff requires you cable to use the 5 pin configuration. I also just bought one of the Titan units for Fanucs. Love it. The guy I bought it from on ebay is quite knowledgeable.
Junior Member
Thanks butt no shore what you mean by 5 pin cable
the cable Ive used is the one supply a DB 9 to DB 18 with a gender changer at the machine end
I do look forward to trying it on my Funuc lathe
Junior Member
Thanks again for an idea were to look it may be around the pins that control ready to send an clear to send setting up a manual hand shack
There are 2 pin configurations for DNC. 3 and 5. Software control only requires 3 pins. Hardware requires 5. If you look up in schematics for DNC you will see. the difference in connections. Always get 5...just in case. A 5 pin works for both setups.
Junior Member
Thanks Ive ordered the right cable To blind these days to solder my own
LOL. That's why I order them, too. Plus, I don't have the patience to troubleshoot something that has a hundred variables, like DNC.
Re: TITAN DNC on PROTOTRAK
If you have a lot of patience there is no problem to fix everything. But you may have really a lot of patience.
- You may not post replies
- You may not edit your posts
Forum Rules
