Some math to consider:
350 lbs of aluminum equates to about 46.66 gals of gas at 7.5 lbs/gal.
Convert that to diesel and it is something like 42.6 gal at 8.2 lb/gal
46.66 gals of gas, even at $3 per gallon, is only $140. Diesel is even less $$$'s
Even today, it is possible to get 20 plus mpg from even a 5+ liter V-8 which equates to nearly 933.3 miles out of 46.66 gals of gasoline. Diesels can get nearly 25 to 30+mpg which makes aluminum even less viable as a fuel
Why would you spend the time and money to drag around 350 lbs of aluminum that has way less potential and/or thermal energy than 46.66 gal of ready to burn gasoline????
Or am I missing something really obvious??????????????????????????
