- Harrison Alpha 400 servo fault, no code?
Hello all,
I have looked through the forum and have seen people posting specific servo faults that their 400s are throwing. I have a similar issue but I do not have the ability(or so I think) to generate a specific code from the fault.
After doing some research I believe I have the "version" of the 400 Alpha that does not have the fanuc control included. There doesn't seem to be a diagnostics screen to look at the fault codes.
The Fanuc main board is a a02B-0259-b501 series 21-tb.
All I see for warning lights inside the panel is a red LED on '2' on the Alarm indicators. All I can see on the operator screen is 'ALARM SERVO'
Any assistance on this?
Thanks!
Re: Harrison Alpha 400 servo fault, no code?
Hi send me your email and I'll send you a diag sheet
My PMs dont seem to be working, can you send me one please?
No they are working fine I have just sent you a sheet
- You may not post replies
- You may not edit your posts
Forum Rules
