Did you ever get the parameters, or the results you need? I am trying to install a new A1000 on a CNC and to am having problems with Rigid tapping and Spindle orient?
Thanks for any help! can you share the parameters that worked for you?
Jeff R.
Hello
Has anyone upgraded there spindle drive to the Yaskawa A1000
If so could I get a copy of the parameters.
The sheet from Haas does not work.
- how to use an oscilloscope to measure drive transistors in spindle drive.
- Gear drive to higher spindle speed belt drive - are kits available?
- Need Help!- I.H. Belt drive conversion spindle drive sleeve gear
- Need Help!- MISSING AC SPINDLE DRIVE + 3 AXIS SERVO DRIVE
- Leaders in importer and exporter of a1000, v1000 and ac motor.
Jeff R.
GOLDCNC5, BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
www.truemachineautomation.com - ETL UL508A CSA CERTIFIED INDUSTRIAL CONTROL PANEL SHOP
