Threading on Haas TL1
Results 1 to 4 of 4
Thread: Threading on Haas TL1
    May 2013
    Default Threading on Haas TL1
    I was using the IPS built in program on the Haas TL1 , it looks like it was feeding in an incorrect angle. What could be the issue? How do I fix this? TIA.
    The Visual Prog didn’t show Any A value but it was feeding in an angle much larger than 30degrees , which made the thread has a much larger angle on the back side of the cut.
    Attached Thumbnails Attached Thumbnails Threading on Haas TL1-128a0432-5f06-4ab1-b22f-477b8704d5e0-jpg
    Oct 2008
    Default Re: Threading on Haas TL1
    Do you have a picture of the IPS screen and settings and the code it produced?
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Some controls require the total thread angle placed in the programming. Others may need the indeed angle ....
    ie. for 60° thread try setting the angle to 30° (some use 29°, to allow the tool to cut a little on the infeed side). Angle is defined as perpendicular to the thread axis (...perpendicular to Z)
    Note... some controls only allow the use of specific numbers (0, 29, 30, 60) check your manual.
    May 2013
    Quote Originally Posted by rwskinner View Post
    let me try that
    Attached Thumbnails Attached Thumbnails Threading on Haas TL1-ea319460-8bbf-4454-9af8-ecbc6f241574-jpg
