Need Help! Hitachi Seiki Hi Cell23 Interpolation Y,Z + X linear movement.
Results 1 to 5 of 5
Thread: Hitachi Seiki Hi Cell23 Interpolation Y,Z + X linear movement.
    Member mexcentro's Avatar
    Jul 2023
    Default Hitachi Seiki Hi Cell23 Interpolation Y,Z + X linear movement.
    We are trying to use a Thread Mill (12mm diameter 18 threads per inch) to make a .6250-18 bore.
    this is our code:
    O0076
    G20
    (TOOL - 1 OFFSET - 1)
    ( THREAD MILL - 0.47)
    M43
    G28 V0. H0.
    G0 T061600
    G19 G98 M44
    G50 C0.
    G0 X1.5 Y.0146 Z.74
    C0.
    G97 S532 M13
    G98 G1 X-.7033 F25.
    G19 G2 I-.7174 Y.021 Z.719 K-.021 F1.5
    X-.7312 Y0. Z.698 J-.021
    X-.759 Y-.042 Z.74 K.042
    X-.7866 Y0. Z.782 J.042
    X-.8144 Y.042 Z.74 K-.042
    X-.8422 Y0. Z.698 J-.042
    X-.856 Y-.021 Z.719 K.021
    X-.87 Y0. Z.74 J.021
    G0 X1.5
    G144
    M44
    M45
    G28 U0. V0. W0. H0. M55
    M275
    M30
    When te machine starts de operation runs into the first positions and start interpolation Y an Z but X doesn't move. I dont know how make the machine move X axis.
    I hope you can help me with this issue.
    Thank you.
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Hitachi Seiki Hi Cell23 Interpolation Y,Z + X linear movement.
    ...delete the G19's
    Jul 2023
    Hello. thank you for your help.
    G19 is the operation for interpolation Y and Z + a (a= linear movement for any other axis that is not on the interpolation) this case is X.
    I will try deleting G19 but then do you recomend other code for replace this operation?
    Again. Thank you so much.
    Aug 2009
    ...the Format would be something like G17G2X...Y....Z...I...J... (for Helical cut)
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Are you trying to use live tooling on a lathe ?
    With a thread in the X-axis?
    G19 would be used.
    The arc is in YZ plane (J&Ks) with pitch control in the X axis?
    Normally threadmilling a R/H thread is to climb cut with a start at bottom of hole moving in CCW direction .... so the chip is not recut & is left under the cutter.
    I don't see any code to start milling mode, or start the live tooling
    ... not sure, but are you programming 4 points for 1 pitch ?
    ... check that X is not doubling pitch in diameter mode. And milling mode turns X into radius values.
    Can your machine interpolate in 3 axis similaniously ?
