- Selling My Entire Metal Shop: CNC, Milling, Turning, Sheetmetal, etc.
Hi guys, its been a while since I have been active on the forums or machining itself -- just life stuff. Now I’m moving across the country from NJ to TX and in the new place I do not have room for the shop. So, I’m selling everything. You can message me offers or post them below. Texting is okay so if you want my phone # msg me. You must pick up the items in Kinnelon, NJ and make the appropriate arrangements to load it in your truck/trailer. Preference will be given for folks getting more than one item. I’ll try to post prices and pictures as time allows. First come first served. All fair offers will be considered. Thanks!!
Fadal VMC15, 16 tool changer carrousel, 7500 RMP spindle. S/N 9311182. Serviced by Axis Machine Tool Service in NJ. Recently (fewer than 50 hours). Replaced bearings for all 3 axis, replaced X-axis resolver, replaced spindle, replaced spindle belt, replaced Z-axis ball screw, replaced keypad and bezel. Checked and tested whole machine. Select liquid coolant vs. compressed air colling via M function. High pressure Graymills 1HP 3-phase coolant pump IMS100-F. Recently painted coolant tank. May need a piston plate replacement. Includes printed Fadal manuals (Maintenance, User, Operator) and service records. (3-phase)
Cincinnati Horizontal Mill with ACU-RITE II DRO. Includes Service Manual and Parts list. (3-phase)
Cincinnati Vertical Mill – Cinova 80. Includes Service Manual and Parts list. Come with large Vise. (3-phase)
Cincinnati Shaper – Includes Operation and Service Manual. (3-phase)
Kent Surface Grinder KGS-818AHD. Includes Service and Instructions Manual for Maintenance and Parts List. (3-phase)
Powermatic Bandsaw. Model 87 with blade cutter/welder.
Grizzly Large Tooroom Lathe G9732. Excellent condition. Includes manual. https://www.grizzly.com/products/gri...al-lathe/g9732
Turn-Pro 712 SG Swivel Metal Cutting Bandsaw. Excellent condition. Includes manual. (120 V)
Roper Whitney Pexto 152M Foot Squaring Shear. Excellent condition. Includes manual.
Grizzly 18” Pan and Box Brake G0542. Excellent condition. Includes manual. https://www.grizzly.com/products/gri...ox-brake/g0542
Grizzly 30-Ton Press H6228Z. Good condition. https://www.grizzly.com/products/gri...op-press/h6228
Husky 80 Gallon, 4HP Compressor. Excellent condition. Includes manual.
Lincoln Electric AC-225 Arc Welder. Excellent condition. Includes manual.
Phase Perfect PT330D Phase Converter (1-phase 54 A, 3-phase 30 A). Excellent condition.
Photos being added below...
Apologies for the delay in posting the pics. Here we go…
Re: Selling My Entire Metal Shop: CNC, Milling, Turning, Sheetmetal, etc.
According to the rules for posting in this forum, you need to post prices for each item.
Mark
- You may not post replies
- You may not edit your posts
Forum Rules
