- Bridgeport with CNC conversion
I've had this for a few years now and looking to downsize with a country wide move. When I bought it had just been through a check by a local Bridgeport specialist that I trust and had used for business work as well.
I have enjoyed this machine a lot and wouldn't even be considering selling it it I wasn't moving.
I know its messy in the photos but that's because I use it all the time and I was doing some ball endmill contouring (hence the quill way out).
If you put in the effort to a solid setup and good G-Code I have no trouble holding .001"
The Belts could use some covers fabricated and maybe some motor mounting improvements or some better belt tensioning.
Includes:
CNC Control Box w/PC and Monitor
UCCNC License
Mist Coolant - CNC Controlled
Air Blast - manually controlled, can be added to CNC easily
HIWIN Ball Screw Upgrade XY
Royal Quick Change Tool Holder
6 assorted tool holders for Royal
Drill Chuck
Cheap Vice
VFD for Powering 1ph to 3ph
Teknic Servo Motors
Looking for $6500 located Buffalo/Rochester NY region
Re: Bridgeport with CNC conversion
- You may not post replies
- You may not edit your posts
Forum Rules
