- 5 axis cnc Mill - SOLD
5 axis cnc Mill
Novakon Bed Mill
NM 200 series 2 up graded to a pro 2hp 1500 watt 150 to 6000 RPM AC VFD spindle motor
4th and 5th axis,
power draw bar, and input for probe
breaking resistor that stops spindle in 1.5 sec from 6000 RPM
Twin LED work liights
stepper motors on X,Y, Z axis
Sunfar 300 controller,
Increased flow coolant system with two independently controlled heads and a wash down hose.
On board computer and Mach3
Enclosure
Table is a massive 38.5 x 12 and will hold 850 lb work load.
Table Travel is 24 inches in (X) 16+ inches in (Y) and 11.5 inches in (Z)
Machine weighs over 1,500 lbs
Under 500 hours , excellent condition
Was never used as a production machine.
List Date: 10/20/2014
For more info, click here to view the original listing: 5 axis cnc Mill
SOLD
- You may not post replies
- You may not edit your posts
Forum Rules
