Hello, I'm trying to find the parameter so when I hit reset it will change the tool number on program check screen, like T0202 hit reset and now it shows T0200 you know dumps the offset. it is dumping the offset but just not showing it on the screen. I want to be able to look at the screen and see if the tool offset is instated or not. I can't find it in the parameter manual, I know I've seen it on other fanuc controls in the past. any help would be great. Thanks
Try with the parameter 5003 bit 6 LVC or bit 7 TGC
LVC Offset value of tool offset
0 : Not cleared, but held by reset
1 : Cleared by reset
TGC Tool geometry compensation value
0 : Not canceled by reset
1 : Canceled by reset
(Valid when bit 6 (LVC) of parameter No.5003, is "1")
#7 #6 #5 #4 #3 #2 #1 #0
