In IPL mode you can enter the options in hex; likely you won't lose any data by only enabling G10. Do you know how to do this?
Hi folks. I search hard and long but did not find answer for that. I'd like to enable G10 option on my mill but can't find the information if it is possible without the need for resetting all parameters and pmc settings.
Basically I just want single option turned on. I know which one it is in IPL mode, I know how to decode it into HEX, i backed up all params, programs and 9000 macros + recorded all PMC params on the phone. But I am bit anxious about the procedure.
So do I need to go through restoring all those parameters back to the control after I go to IPL mode by pressing - and . and changing this option? Perhaps it's just possible to go to IPL change only the option you need exit and good to go?
Thank in advance.
when you go to IPL menu you just need to press enter for options you want to keep and change the value only for the option you need to change
@memoryman, in theory I know. Never done this before. I'm IT guy so I know my ways around bytes and hex notation. I read on forums that you can go to IPL and by just press enter for options you don't change they stay the same. Supposedly at the end of the procedure it asks to clear the files (saw it on YT video) and this bit worries me. I don't want to risk clearing entire control from params and programs
I'm talking about this question: Will I also get this question to clear after I change only one parameter?
The procedure or the 11 is not the same as the 15.
"Supposedly at the end of the procedure it asks to clear the files (saw it on YT video) and this bit worries me." It will clear only what is necessary; for G10 it is very little.
Btw, in IPL mode, enter "99", press ENTER, it will ask for # of axes, enter that, then the OPTIONS. Then answer Y (ok to CLEAR).
You can lose your data anytime, so always be prepared to restore the data by having complete backups.
