in engineering the company solidworks have, the more I have the CD's that came with the machine that are typeedit3, artcam, dsp.
more after the soft how do I bring to the machine
Diego, in order to operate the machine - You need to firstly understand the chosen software program.
Do you know somebody that has worked with CAD programs? If so, you will need to gain their assistance. No cnc machine will operate correctly if you do not know how to program it.
Which software are you intending to use?
Rocket.
Have a look at the thread titled " how to operate the Excitech "
If you do your design work in solidworks - i believe that you can then import it into the type3 software which will then generate toolpaths and G code to send to the machine. You must insert the USB stick into a port on your computer when you begin programming and then save it to the USB stick when you finish. Then you put the USB stick into the DSP controller. The machine will interpret the contents of the USB stick and away you go.
But before any of this you need to learn how type3 works.
Rocket.
then only need type3 software so you can make the machine operates. and the rest in proprio dsp
