If you build the machine nice and tight you will be fine. The problem comes in when you are cutting close to the side of the gantry. The screw is in the middle, so the gantry wants to skew. I would consider making the gantry sides wider, so that there is more space between the guides. The moving table scheme eliminates this problem because the guides are spread way out at the corners of the table.
Eric
