Thanks very much for all the insightful replies.
Fantastic, I've been looking, and there really are quite a few options. I'm looking at something like this for the long axis:
SBR16 Linear Rail Support Aluminm Assembles 2pcs L1500MM 4pcs SBR16UU | eBay
The question is, what diameter should I shoot for on the supported rail? The gantry might end up being 50 lbs (1/4" steel side plates, two supported rails, their crossmember, and rack/pinion).
Are you saying you would use tubing as the gantry crossmembers? I was looking at a design where they bolted in the linear rod (unsupported) as gantry members, which seems quite efficient, especially if used in conjunction with at least one supported rail.
CNC Engraving Machine CNC Frame CNC DIY 3040 Aluminum Alloy Ball Screw | eBay
All very good suggestions. It may end up that I HAVE to design my own Z carriage, just because I'm thinking about using linear rails on either SIDE of the spindle, as well as two behind, as it is traditionally. From the standpoint of Z-axis deflection on harder materials (aluminum), that would seem to make more sense to me, especially if I just bolt them in (as above).
But, if I find one for cheap, I'll settle. Just have to find some machines in the local scrap yards.
You think profile rails are better than supported rods? Just asking, because I have no idea. All the nice machines I've ever seen use rods, from what I remember.
Out of curiosity, would that 15mm rail support a 5' long steel gantry? I see they make wider ones, but I can't find many for sale.
