- DNM 650- G5.1 is overwriting my 1432 parameter, causing a 5011 PARAMETER ZERO error
Hi Guys,Tried to take a 4th axis simultaneous cut, get a 5011 error.Changed parameter 1432 from 0 to 3000, program ran fine. Tried to run a roughing cut that had g5.1, program errored back out.Checked parameter 1432, it was set back to 0.Removed g5.1 from my program, set 1432 to 3000, program ran fine, and stayed at 3000.Can you think of a reason g5.1 would be setting this to 0?
- You may not post replies
- You may not edit your posts
Forum Rules
