Daewoo Puma 8HC-3A Tailstock question
Results 1 to 7 of 7
Thread: Daewoo Puma 8HC-3A Tailstock question
    Jan 2008
    Default Daewoo Puma 8HC-3A Tailstock question
    Is there a mechanism or procedure (other than beating the live center with a hammer) to remove a live center from the tailstock quill?
    BTW, we do not have manuals for this model.
    Cheers,
    Steve E
    Dec 2015
    Default Re: Daewoo Puma 8HC-3A Tailstock question
    which controller model with machine fanuc or mistubushi???
    quick-cnc
    Jan 2008
    Quote Originally Posted by phucrobusl View Post
    The control is Fanuc 15TF, & we do not use the conversational language feature of the control. We only use straight G-code.
    Cheers,
    Steve E
    Member dhardt's Avatar
    Feb 2013
    Without the exact serial number this is the best guess on the parts section...
    Attached Files Attached Files
    No longer with Doosan Machine Tools America
    darrylhardt@gmail.com
    Jan 2008
    I figured out the technique. I use the locking nut (item #44 on drawing) to force out the live center. Sorta like a collet in reverse.
    Cheers,
    Steve E
    May 2009
    thanks
  7. #7
    Member PeruCncLima's Avatar
    Aug 2021
    Quote Originally Posted by dhardt View Post
    Amigo buen día, quisiera saber si usted tiene algún respaldo backup para mí maquina Daewoo Puma 230 control Fanuc 21i-T año de fabricación 2000.
    Se daño nuestro controlador y tenemos problemas porque no tenemos el respaldo de nuestra máquina gracias.
    Attached Thumbnails Attached Thumbnails Daewoo Puma 8HC-3A Tailstock question-img_20240314_085156-jpg
    YamilTS
