The Program has a lot of junk in it and is not good the way it has been processed
( SADIE V CUT5 )
( File created: Friday September 30 2022 - 02:18 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 34.000, Y= 13.000, Z= 0.750)
(Toolpaths used in this file
(SADIE V CUT2)
(Tools used in this file: )
(5 = V BIT 60)
N100G00G20G17G90G40G49G80
N110G70G91.1
N120T5M06
N130 (V BIT 60)
N140G00G43Z0.8000H5
N150S12000M03
N160(Toolpath:- SADIE V CUT2)
N170()
N180G94
N190X0.0000Y0.0000F100.0
N200G00X0.8238Y-1.5406Z0.2000
N210G1Z-0.0625F30.0
N220G1X0.8296Y-1.4952F100.0
N230G1X0.8361Y-1.4543
This very first line is incorrect ( X= 34.000, Y= 13.000, Z= 0.750) it is in brackets so won't do anything there is no reason for it to be there
N140G00G43Z0.8000H5 then this is your first Z axis move, this should put the Tool .800 above the part if it does not then you are doing something wrong when you set your tool offset this is your G43 call H5 is your Tool # so in the tool offsets you have to have that tool offset highlighted when you set the tool
G70G91.1 may switch you to incremental mode which can cause problems this is not needed, this is not needed and should be removed
N180G94 this is not needed also
I would try some different Post processors
So, going by what I see this program should run ok but has a lot of junk in it that should not be there
