Working On A New "Timber Frame" Design and Build. - Page 4
Page 4 of 8 FirstFirst 1234567 ... LastLast
Results 61 to 80 of 159
Thread: Working On A New "Timber Frame" Design and Build.
  1. #61
    Default Re: Working On A New "Timber Frame" Design and Build.
    Putting the first column together with the bolt plates installed and loose tenon joints holding it all together.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-img_9271-jpg   Working On A New "Timber Frame" Design and Build.-img_9272-jpg   Working On A New "Timber Frame" Design and Build.-img_9273-jpg
  2. #62
    Little by little it is coming together. Test fit of the first gantry side plate, column and beam connect plate are looking good, I put the second column together this evening, so glue is drying on it now.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-img_9277-jpg   Working On A New "Timber Frame" Design and Build.-img_9282-jpg   Working On A New "Timber Frame" Design and Build.-img_9283-jpg
  3. #63
    Had to through the cut panels for the beam up on the columns just to see how it is going to look.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-c369c030-dfec-411a-a131-02938ba5f63b-jpg
  4. #64
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by peteeng View Post
    Hi Loren - Like those big washers what are they from? Peter
    You should be able to find them any good fastener supply should have them, Fender Washers
    Mactec54
  5. #65
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Mactec - In Oz the are called mud guard washers and although large in dia they are thin and can bend when cranked up on timber. I use large square washers used for timber framing they are 3mm thick or 1/8" and they work well. Peter
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-square-jpg
  6. #66
    Jan 2005
    Fender Washers can be any thickness, normally they are standard washer thickness which are the same thickness as what you are using like this snip, square is good though will have a little more surface area
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-fender-washers-png
    Mactec54
  7. #67
    I made some good progress over the weekend. I finished building the gantry beam, installed the linear rails, and the rack on the beam. Then mounted the beam and and got it level and plumb. Then muscled the Z-axis up and installed it on the beam rails.
    On Friday I ordered motors, cables, a power supply and some electrical drag chain.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-img_9304-jpg   Working On A New "Timber Frame" Design and Build.-img_9303-jpg   Working On A New "Timber Frame" Design and Build.-img_9307-jpg   Working On A New "Timber Frame" Design and Build.-img_9306-jpg
  8. #68
    Jul 2018
    dum dum
    Hi Loren - The monster is coming to life. Peter
  9. #69
    Jul 2018
    dum dum
    Hi Loren - You used four rails for the gantry any particular reason? Usually only two? Regards Peter
  10. #70
    Four rails?? There are two on one the table, one and each side. Then two on the gantry beam front face, one upper and one lower.
  11. #71
    Jul 2018
    dum dum
    Hi Loren - you have 4 rails under the gantry, usually only one each side? You have two each side? Peter
    edit - opps I see now that photos on its side!! Peter
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-rails-jpg
  12. #72
    For some reason, the forum flipped the photo when I uploaded it.
  13. #73
    Paint….lots of paint.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-df006fa9-fe9d-452a-903c-393892d6ca0d-jpg
  14. #74
    Paint is complete, even the belly of the beast was painted.
    I ordered a 2.2 KW G-Penny spindle and a Hitachi WJ200-022SF VFD to power the spindle. I need to make a spindle mounting tram plate to fit the spindle. I ahve it designed, just need to program it and get the big vice set back up on the Tortoise to cut it. The one I already made was for an ATC spindle, and just could not justify that cost right now.
    The main power supply landed today. I'm getting the other electrical components ordered as I sort through the rest of the electrical build.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-img_9315-jpg   Working On A New "Timber Frame" Design and Build.-img_9316-jpg
  15. #75
    I installed the X &Y axis hard stops today and started working on the spindle mount plate.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-img_9318-jpg   Working On A New "Timber Frame" Design and Build.-img_9319-jpg   Working On A New "Timber Frame" Design and Build.-img_9320-jpg   Working On A New "Timber Frame" Design and Build.-img_9321-jpg
  16. #76
    Jul 2018
    dum dum
    Hi Loren - Those timber thread inserts are really good. When do you think sawdust will happen? Peter
  17. #77
    Hi Pete, I’m probably another 4+ weeks out to having it cutting. I have all the electrical, and still have some components to fabricate for the rotary axis.
  18. #78
    Cutting the spindle mounting plate on the Tortoise. Slow but steady!
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-b2fff8fb-03a2-47b1-85a0-423b2c3eb0a5-jpg
  19. #79
    Finished up the new spindle mount plate.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-73c12c31-4129-4ebe-9ac6-2d8430bd8bb2-jpg   Working On A New "Timber Frame" Design and Build.-c33b3fd4-35d8-4594-87e4-11ae7988bfff-jpg
  20. #80
    This is a tie plate between the gantry column and the gantry beam. I had a little bit of gap between the tie plate and the beam. The beam is masked off and epoxy buttered the mating side of the tie plate common to the beam to create a perfect fit shim.
    Attached Thumbnails Attached Thumbnails Working On A New "Timber Frame" Design and Build.-efde0601-0142-42ec-9761-7c5cc6e108d4-jpg
