What controller?
hi guys i am a complete rookie in cnc world. Where i work , we buyed a twotrees cnc (TTC450) we have installed all drivers, but we have the z and y axis inverted on the offline controller, while the x axis is good. Can you please give me a solution and what's causing this problem? Thank you in advance.
What controller?
http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
The controller is the makerbase dlc32 v2.1 but is from another producer, because the TwoTrees give us the TTC450 cnc with a defective motherboard and we've changed. We buyed a new makerbase dlc32 v2.1 from amazon. The monitor is the MKS TS35-R V2.0 and is all the same but now Y and Z are inverted when i use the controller or grblesp, for example, If i click the "up arrow" the Z will go down and is the same thing with the Y axis.
