dont let me put you off any program that may cost you thousands and may or may not work...lol
in sheetcam post i used drills as tool numbers 100 plus drill number set for correct size in sheetcam. checked if drill was over 100 if it was subtract 100 (to give drill head number) and call drill cycle g99.
for horizontal drilling draw 0.1 , 0.2. o.3 or 0.4 diameter hole on board edge(which wouldnt exist as real drills on my machine) depending on side to be bored. call relevant drill cycle!
it works brill.
re mach. i have 30 vertical 10 horizontal to program.
i will use the same sort of setup but each tool size will call a different m code.
this will be easier to set sheetcam to do. (i have yet to write a post for vectric vcarve but im sure it wont be too hard)
eg. m1601 will be drill 1 m1602 drill2 etc (that way i can offset the drill from original toolpath etc, set offsets and do correct cycle for that drill (vertical or side 1 2 3 or4 etc. set whatever rpm ie for bigger bits need to go slower?
i should have the 335 moving on sunday . have to go deliver one of my fantastic pool tables in london tomorrow . darn work is getting in the way of fun.
what plasma source does the burny have? i have hypertherm 1000.
ive had to dismantle mine for the moment as the 335 has used up all my space. (not many people with 2 5 tonne cncs in their garage i bet!)
bet theres not many people that use diesel to run all their machinery either! the joys of living on a mountain.
