Reinstalled my FEA software, unfortunately the latest version is full of just as many bugs as the last version.
But after many hours fighting it I finally managed to get it to spit out the deflection of the beams I was thinking of using with 500kg at the centre point.
Even at 50 metric tons this beam(2.5m x 200mm x 200mm x 10mm) is only deflecting 3mm.
I see that HAAS have a deflection test for their spindle which is 0.0762mm with 1000lbs(~500kg)
https://www.haascnc.com/service/trou...---ad0599.html
Anyone know what the average accuracy of top end CNC milling machine is with 500Kg force on the spindle?
