huanyang gt series gt-011g-2 running a 7.5 hp spindle issues
I have a huanyang gt series gt-011g-2 VFD
It has auto tune but it blow a fuse when i try and run it
My spindle is a vevor
300Hz
RPM 18000
KW 7.5
AMP 15
2 POLL
On the programming it said to enter this data from spindle from plate
P2.01 Motor Power i put in 7.5
P2.02 Motor frequency (It will only go from range 0-50hz) I put in 50
P2.03 Motor speed 18000 is what i put in
P2.04 motor voltage 380 also tried 220V
P2.05 motor amp 15
It then says run auto tune P0.16 (option 1) then run
I also tried manually entering this data Is 300 wright on 50hz?
P0.03 I Set to 300
P0.04 I Set to 300
P0.06 I Set to 300
P2.02 I set to 300
Still blows fuse
I toned out the spindle wiring and installed a different brand that i am replacing because its under powered, It works fine.
It has auto tune but it either blow a fuse when i try and run it or trips the vfd
Spindle makes a ruff sound on starting before it trips.
I toned out the spindle wiring and installed a different brand that i am replacing because its underpowered, It works just fine.
My spindle is a vevor 7.5Kw or 10HP
Plate Info
300Hz
RPM 18000
KW 7.5
AMP 15
P2.04 motor voltage 380 also tried 240V as well
P2.05 motor amp 15
I also tried manually entering this data Is 300mhz on 50hz?
P0.03 I Set to 300
P0.04 I Set to 300
P0.06 I Set to 300
P2.02 I set to 300
Re: huanyang gt series gt-011g-2 running a 7.5 hp spindle issues
First, some forum housekeeping. You seem to have created similar threads under two different account names, and in two different sub-forums. Please do not do that in the future. I have combined both into this single thread. Please decide which one of those accounts you will use and stick with that one. And creating duplicate threads is not permitted -- it gets very confusing to other members once one of those threads gets a reply.
Next, you have not stated what source input power you have available to drive this VFD. Do you have 3-phase AC or single phase AC coming into your building? (If you are in North America its rare that a house will have 3-phase available.) What is the rating of the circuit breaker(s) in the building's breaker box for the circuit you wired the machine to?
It seems odd to me that the model number you stated, "gt-011g-2" is not exactly listed in the chart on page 4 of the manual. To me it looks like the the "011G" part suggests 3-phase, yet the "-2" part suggests single phase.
