lambda 21a
Results 1 to 3 of 3
Thread: lambda 21a
    Francoadi's Avatar
    Oct 2022
    Default lambda 21a
    Hi...
    Recently I purchased a cnc controller of
    "Weihong nk280b", with "Lambda 21a"
    It is very hard to find information or instructions
    about, how to wire everything to my cnc table components.
    Such as a VFD spindle, ATC tool control system, limit switches .
    It will be very helpful if enyone can help me with that.
    or It will be very helpful if you can draw all the wiring, on the lambda 21a board.
    Tanks very much
    Adi Franco
    Aug 2017
    China
    Default Re: lambda 21a
    hi ,it is Weihong system from China , do you have the manual ? contact with me on whatsapp +8618560201508 then engineer check if supply support to you .
    Dec 2017
    Libyan Arab Jamahiriya
    Quote Originally Posted by Francoadi View Post
    Hi...
    Tanks very much
    Adi Franco
    Did you find any manual for this please help
    - - - Updated - - -
lambda 21a
lambda 21a
