How do you (personally) use tool offsets in Mach 3?
I've been just touching off each tool, and wanted to try using offsets.
I measured all my tools+holders from tip to the spindle face (Tormach tts holders), and then zero'ed my spindle face on a 123 block. I subtracted the 3in from the block to get zero.
I was trying to turn off tool offsets on the Mach 3 offsets page, but my code was running a g43 that apparently turns it back on. I also found I had zeroed my spindle a time or two with an active tool offset.
Seems if I change a drillbit in a chuck that has the same tool number/offset, I just touch it off and update the tool offset and all is good.
Yes took a bit to wrap my brain around on mach4, be nice if the offset would apply when a different tool # is entered in the program run screen instead of having to go and cycle the toggle height in offsets
