I just purchased a optimum bf 20 mill and want to buy a belt conversion kit for it. I want to run faster than the machine currently runs and I’m concerned I will destroy the plastic gears. I have seen the kits on you tube but can’t find where to buy one. The videos are quite old as well.
Any ideas?
Kim
Fundamentally, with a belt drive you do not use the gears any more and as regard the other posters comments the motor would be geared by the chosen pulleys
to remain in the same rpm / torque range so no chance of damage! The usual primary concern is the spindle bearings, as most only have a speed rating similar to
the max provided by the original gear ratio say, 3000rpm, so upping the speed to say, 6000rpm will usually cause bearing overheat and failure! If you have access
to a lathe buying the timing belt pulleys on line and machining them to fit motor and spindle isn't rocket science and proved to be quite cheap overall for me.
