Hi, I picked up a cnc router in a trade that was non functional and am working on bringing it to life.
It is a typical 1530 framed setup:
- with a moving gantry
- DIY build
- appears to mostly use avid parts such as the linear bearings and stepper motor mounts and many of the conventional drive components:
It was set up to have the stepper motors in line with the 2 turns per inch screw drive but it is much better for me if the motor is mounted off set and driven from a belt to the shaft.
I could use some advice on over coming how to deal with mounting things to work.
Here are a couple of photos of the mock up that shows roughly the location. Obviously not finished mounting things but it shows the general idea and what I am trying to figure out.
I can't see how the mount works with a nema 23 motor mounted to 15 series material as the hole does not align to the slot. If it aligns with 2 slots of the 1530 that would be even better but I will take what I can get.
