Hello... So my auto z touch plate was working fine yesterday and today when I set the magnet on the collect it doesnt close the circuit. The touch plate still shows inactive in Mach 4. If I put the magnet on the touch plate the plate shows active in mach 4. Any ideas. Thanks!!!
- auto z touch plate
- Auto Z touch plate troubles
- Need Help!- Script for Auto Z Touch Plate
- Need Help!- auto zero touch plate
- Problem- Auto Z Touch Plate
Ha, I just had this happen yesterday, with the caveat that I have modified my magnet connection a bit.Hello... So my auto z touch plate was working fine yesterday and today when I set the magnet on the collect it doesnt close the circuit. The touch plate still shows inactive in Mach 4. If I put the magnet on the touch plate the plate shows active in mach 4. Any ideas. Thanks!!!
Check to make sure all wire connections are tight, especially where it is bolted onto the magnet.
