Page 1 of 3 123 LastLast
Results 1 to 12 of 31
Thread: Any info on the TTS Flycutter?
    Registered cheetahcnc's Avatar
    Oct 2007
    Question Any info on the TTS Flycutter?
    I've seen the TTS flycutter running on a PCNC 1100 at a show, and in one of the latest videos Tormach released. Any news on when it will be released? Couldn't find much about it except a mention here:
    Tormach Tooling System: What
    ...and the video squaring an aluminum block using the flycutter here:
    http://www.youtube.com/watch?v=RhVtJ6bRDl4]Tormach - How to Square up a Block with a CNC Mill - YouTube
    Jim
    Mar 2009
    us
    Jun 2006
    Zip Fly??
    Registered zephyr9900's Avatar
    Feb 2006
    TseTSe Fly
    Oct 2007
    Thanks for the link. Looking forward to getting one of these.
    Jim
    Oct 2007
    Registered Scott_M's Avatar
    Apr 2006
    Medina , Ohio USA
    I was in the beta tests for the new fly cutter and did some extensive testing on the "SuperFly". It is very impressive. I compared it to the Glacern FM45-250 Face mill In both steel and aluminum the SuperFly had almost double the MRR using the same inserts. This is because the fly cutter is only turning 1 insert. Each additional inserts sucks up horse power. On a low horse power machine the fly cutter will win . I am sure if we were talking about a 10+ HP spindle the Glacern would blow away the fly cutter. But on the Tormach this fly cutter was far more efficient. The best I could do with the SuperFly in aluminum was a cut .035" deep @ 100 ipm for a MRR of 8.75 cu. in.( this cut was in the red ) The video below is .030" deep. The best MRR's I could get with the Glacern were 4.5 cu. in.( alum. ) and 1.25 cu. in ( steel ) The SuperFly got 2.125 cu. in. in steel.
    The biggest drawback to this kind of MRR is the amount of chips distributed all over your shop !! If you look in the video you can see that I have cardboard extensions on the guards, they helped a little bit.
    I talked to Andy at Tormach and he should have a blog post coming out soon for the SuperFly.
    http://www.youtube.com/watch?v=QXT9uBOmD5Q&feature=plcp]Super Fly Tests - YouTube
    www.sdmfabricating.com
    Oct 2007
    Quote Originally Posted by Scott_M View Post
    Sounds great. Ordered one on Thursday, should be here soon. Another excellent advantage of this tool, in addition to your fantastic results, is it only requires one insert. I already have two Tormach face mills (four inserts) which will still get used, but this tool with those numbers is a big plus.
    Any clearance issues for the ATC?
    Jim
    Apr 2006
    Medina , Ohio USA
    I do not have an ATC so I can't say for sure. The SuperFly does have an ATC Groove so it probably works fine.
    Scott
    Oct 2010
    Any idea what the minimum diameter will be? They mention a max of 3" on the website but no minimum.
    Registered David C. Allen's Avatar
    Jan 2007
    I asked Tormach here is their reply:
    The fly cutter radius is adjustable from about 1.25" to about 1.85". That is with keeping all three set screws on the tool bar.
    David
    Registered Steve Seebold's Avatar
    Mar 2009
    San Clemente, CA
    I saw it working today at Little Machine Shop open house. All I can say is WOW.
    You can buy good parts or you can buy cheap parts, but you can't buy good cheap parts.
  • Page 1 of 3 123 LastLast
    1. Taig Flycutter
      By 5artist5 in forum Taig Mills & Lathes
      Last Post: 05-19-2013, 08:43 PM
    2. Flycutter tool bit for aluminum?
      By lcvette in forum Benchtop Machines
      Last Post: 02-06-2012, 06:41 AM
    3. Flycutter for Proxxon MF70
      By dash2099 in forum Benchtop Machines
      Last Post: 11-01-2010, 09:55 PM
    4. Proper use of a flycutter
      By JWeb in forum Benchtop Machines
      Last Post: 08-20-2010, 02:12 PM
    5. Flycutter shank style
      By thackman in forum Benchtop Machines
      Last Post: 03-07-2007, 12:41 AM
