As I said it in one of the other posts, you have to look at the cost and your spindle cost, is it beneficial to have one yes, is your spindle going to run better, in general Yes it will, In some country's you have no choice it has to be installed along with the input Filter.
On installs I have found input power Filters to be more beneficial for your whole system, and of cause using both if cost is not an issue, it is worth the extra to protect expensive spindle motors, cheap spindles that's up to you, if you have a noise problem, this will help with that
