I believe these are the option parameters, you would have to find someone with the same make of machine.
Dear Forum,
I am looking for 3M parameter, just no. 0001,0002,0003.
thank you so much.
Nastek
I don't have for a mill, only a lathe, you may want experiment with some and see what happens?
The Lathe is
0001 01110001
0002 00100000
0003 00000000
This is all the information I have.
I have not verified it.
FANUC 3M PARAMETERS
Parameter 0001 bit 7 is enable Z brake
bit 4 enable spindle start
Parameter 0003 bit 6 turn on the variables for macros, bit 4 turn on the menu screen
Parameter 996 bit 3 enable 64 offsets
Parameter 997 bit 4 clock and part counter, bit 2 3 axis simultanious. Parameter 998 bit 7 turn on operator panel
P1 10000000 Enable Z brake
P1 00010000 Enable Spindle start
P3 01000000 Macro Variables
P3 00010000 Menu Screen
P996 00001000 64 Offsets
P997 00010000 CClock and Parts Counter
1.7=PMC on
1.6=GSP special G code
1.5=INCH/Metric
1.4=Sanalog 4 Digits
1.3=Mpg Hndl/Step
1.2=0FLUP
1.1=G10
1.0=FIXA
2.7=MFX
2.6=Fanuc tape drill M06
2.5=I/O interface
2.4=CRC
2.3=Mem1
2.2=Mem2
3.7=THIN teach in
3.6=USER MACRO
3.5=PEC
3.4=MENU (Ptrn Data input)
3.3=MACMC
3.1=HAX2
3.0=HAX1
Dear F-BU
Last few days, i get parameter from Fanuc 2M (Yoshida), my machine is OKUMA&HOWA 4V-NC (Tape Drill)
0001: 10101011
0002: 00101000
0003: 01000000
with this parameters,the machine can run
but Handle not work and Lubricator on-off quickly (lubricator run by timer).
in your explanation, Handle/MPG setting on 0001 bit 3, same with my parameter.
X,Y,Z have each Handle (3 Handle).
Can you explain to me, how to set these handle and Lubricator?
i am very confused
Sorry for my english
Greeting
Nastek
Well, if OKUMA&HOWA 4V-NC (Tape Drill) has 3 handles, than set 3.1=1, 3.0=0 for 3 MPG. For the lubricator, timers must be set to diagnostic numbers 204 and up. DGN204, 205 and 206, 207 are 16-bit timers, unit 50 ms. For example 50 minutes are 3000000 miliseconds, div 50 is 60000=EA60. Then 204=01100000, 205=11101010. DGN208 is timer 3 etc. Timers above 3 are 8-bits, 50 ms unit, so 1 second is 00010100.
Hope this helps
Dear F-BU,
Thank you, your answer is very help me.
handle ok, temporary, i set lubricator with additional electric timer.
Nastek
